Jkb24
Feb 06, 2022Tutor
Orbi RBK12 Ethernet Connections Issue
Wireless connectivity no issues. All Ethernet connected computers and devices no IP address provided by ORBI DNS, so no internet connection. Orbi connects to Spectrum modem via Ethernet cable at in...
Feb 06, 2022Guru - Experienced User
What spectrum modem is it?
What firmware is on the orbi?
What switch is connected to the orbi?
If devices are directly connected to the orbi (without switch) do they work?
- Jkb24Feb 06, 2022TutorThanks for the rapid response
Yes all indications are it’s the switch as connecting to the lan port is normal with internet connection. I cannot access the router setup page using my PC connected directly to the orbi lan port. Using the Orbi app on my phone does not connect to the oribi setup page but to a sign in requesting email address and password neither of which I can remember or can get with the possible combinations. I simply want to get to the Orbi setup page. Should I be connected to the internet port of the orbi instead?
I have reset the Admin password on the Orbi but did this using the Netgear tool which needs the orbi serial number.
Can you help me get to the orbi setup page so i can see the FW version and other data?
Thanks- plemansFeb 06, 2022Guru - Experienced User
Yes all indications are it’s the switch as connecting to the lan port is normal with internet connection. I cannot access the router setup page using my PC connected directly to the orbi lan port.----how are you access it? Using its ip address? using the routerlogin . net? What method? Using the Orbi app on my phone does not connect to the oribi setup page but to a sign in requesting email address and password neither of which I can remember or can get with the possible combinations. I simply want to get to the Orbi setup page. Should I be connected to the internet port of the orbi instead?----NO, the computer shouldn't be on the wan port.
Thanks- Jkb24Feb 06, 2022TutorUpdate:
I was able to connect to the Orbi only using my iphone (wifi) but the tiny print from the page was almost unreadable on the iphone. The Orbi internet port connected to modem as normal. Had to use the ip address of 10.0.0.1 to access since previous gateway was changes likely due to the FW version noted as 2.7.3.22, originally 192.168.1.1, so i set it back to this IP under advance settings.
Still no connection through switch for all wired ethernet devices. Could the FW be at fault? here
