FayeM
May 19, 2020Initiate
Orbi RBK12 mobile phone issue
Hi. I set up the Orbi Wifi extender a week ago. I have great wifi coverage throughout the house on our laptops now where as previously had none in the far side of the house. The problem I have is ...
- May 26, 2020
Mark your post as solved so other will know.
Enjoy. :smileywink:
May 20, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
FayeM
May 26, 2020Initiate
Thanks a lot FURRYe38 and sorry for the delay in replying. I'm a shift worker so waited until I had some time off to go through your solutions. I knew the satelite was placed okay so I turned off Armour, set the router to 2.4Hz and then rebooted and fingers crossed it seems to be working fine. Early days but feeling hopeful. Also managed to get Chromecast working on 2.4Hz. Will leave on 2.4 and not bother changing back to 5Hz as the speed seems fine and no glitches. Really appreciate your help. Cheers, Faye
- FURRYe38May 26, 2020Guru - Experienced User
Enjoy. :smileywink:
