whoareyou16
Feb 10, 2020Follower
Orbi rbk12 question for a small location but fast internet
Hi everyone, I am new to the forum and am looking for advice with maybe buying an Orbi RBK12 for a small place about 1000ft. I have a 200Mbps cable internet connection and was wondering if that ...
Feb 11, 2020Guru - Experienced User
How would your speed be capped at 100Mb? Unless your wired PCs network adapter was only supportive up to 100Mbps. Then you would see the cap there.
The 1 series Orbi has the following specs: https://www.netgear.com/images/datasheet/orbi/RBK12.pdf
Ports – Orbi Router
- Two (2) 10/100/1000Mbps Gigabit Ethernet
ports
- One (1) WAN & one (1) LAN
Orbi AC1200 Router & Satellite
(866 + 400Mbps)†
What Firmware is currently loaded? Built in router here by chance, if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options to consider,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
