BrenHam
Feb 13, 2023Follower
Orbi RBK13: Correct password isn't working on iPad
Help! I needed to change my password on the Netgear site (using desktop computer). Dealing with another problem (security camera), the support person (Blink) told me to "forget" my Orbi login info ...
Feb 14, 2023Guru - Experienced User
You changed the login info for the router? or the connection info for the ssid (wireless network)?
Not sure as you weren't very clear
michaelkenward
Or the access login for this site? Or MyNetgear?
These passwords are sent to try us.
