exitcy
Jan 18, 2022Aspirant
Orbi RBK13 Latency Degrading
Hi, Recently I made a move from a 3,500 sq home to a 2,500 sq home, and after setting up my old orbi RBK13 system, the latency degraded heavily. I am not sure if its because the smaller home caus...
Jan 19, 2022Guru - Experienced User
a couple details.
1. what modem/gateway do you have?
2. what firmware is on the router?
3. what are the interior walls of the home made of?
4. have you tested the latecy at each point (at the modem, hardwired into router, hardwired into satellite, then wireless on router, wireless on satellite)? That helps determine how everything is working/functioning
- exitcyJan 26, 2022Aspirant
1. netgear CN1000
2.V2.7.3.22
3. I have wooden walls
4.I have tested the latency at each point of my house. The latency when it does spike affects the whole house, so the different location testing didn't really help.
