exitcy
Jan 18, 2022Aspirant
Orbi RBK13 Latency Degrading
Hi, Recently I made a move from a 3,500 sq home to a 2,500 sq home, and after setting up my old orbi RBK13 system, the latency degraded heavily. I am not sure if its because the smaller home caus...
exitcy
Jan 26, 2022Aspirant
1. netgear CN1000
2.V2.7.3.22
3. I have wooden walls
4.I have tested the latency at each point of my house. The latency when it does spike affects the whole house, so the different location testing didn't really help.
Jan 26, 2022Guru - Experienced User
A couple things.
1. have you tried making sure ipv6 is enabled?
2. have you tried a different dns provider? (make sure if you do to enter one for ipv4 and ipv6)
- exitcyJan 26, 2022Aspirant
1. ipv6 is enabled.
2. Can you elaborate on the switching dns?
- plemansJan 27, 2022Guru - Experienced User
There's a guide on changing dns servers.
https://kb.netgear.com/30510/How-do-I-set-static-Domain-Name-System-servers-on-my-NETGEAR-router
That shows you how to do it for IPv4 but if you go into the IPv6 there's also settings for that.
You could try googles at:
IPv4: 8.8.8.8 8.8.4.4
IPv6: 2001:4860:4860::8888. 2001:4860:4860::8844
the :: is for the boxes left blank or with zeros
