jhughes
Jul 19, 2021Aspirant
Orbi RBK13 Ports
I just bought the Orbi RBK13 Mesh system thinking it was an upgrade. However, I work from home and need to connect my VoIP phone and printer/scanner to my router. This doesn't have ports for that. ...
Jul 19, 2021Guru - Experienced User
Yes you can add a external 1Gb LAN switch to the back of the RBR for expanding LAN ports.
NG GS105 or 108 would work.
https://www.downloads.netgear.com/files/GDC/datasheet/en/GS105v3-GS108v3.pdf
jhughes
Thank you SO much!!
