Mom2Halo's avatar
Mom2Halo
Follower
Mar 10, 2021
Orbi RBK13 quit working after just less than a year
We have had the Orbi RBK13 mesh router for 11 months. Just last week they just quit working. I've tried just about everything. Last thing I tried was resetting them to factory by sticking a paperclip into the reset hole of the main modem. Now I am to the main set up. I follow the directions exactly as stated on my phone. It keeps telling me ethernet cables not detected. I did absolutely nothing different. It has all the same cables attached that it has had over the past 11 months and just decided to quit working. Has this happened to anyone? I can't do a firmware update since I reset it back to factory it doesn't even register that I have an account since I can't set it up.
Thank you in advance for your help.
  • plemans's avatar
    What modem/gateway is it connected to?
    You said it says "no ethernet connected"? Is that from the modem? or a device connected to it?
    What firmware version are you on?
    Have you tried hardwiring a pc/laptop into the RBR10 for setup?
  • CrimpOn's avatar
    CrimpOn
    "main modem". Is that a typo for Orbi RBR10 router?
    Orbi comes with a 1 year warranty.  My first step would be to contact a forum moderator with the information about this purchase and inquire how to get a Return Material Authorization (RMA) for the defective product.  At the very least, you want the problem reported before the year warranty expires.
