2squared
Jun 27, 2022Aspirant
Orbi RBK13 Voltage Support
I'm planning to buy Orbi RBK13 in USA and use it in India. Would it work without any issues? Also, the adapter reads 100-120v. But the voltage in India is 220v. I've read multiple posts saying that...
CrimpOn
Jun 27, 2022Guru - Experienced User
In addition to the voltage issue, Netgear routers sold in the US will have a region code of "NA" (for North America). I have a suspicion that these units do not allow the user to change the region code, whereas units sold overseas are more likely to. WiFi radio frequencies differ by county. Region code is what determines which frequencies the Orbi will use.
Is the cost savings from purchasing in the US (as compared from Amazon in India) great enough to take the risk of not being able to use it there?
2squared
CrimpOn I paid around $70 for a 3-pack, and its almost double in India. If the region cannot be changed, does it mean it will be unusable?
- CrimpOnJun 27, 2022Guru - Experienced User
It means that the WiFi system will operate on US frequencies. The way I read it, 5G WiFi frequencies in the US are similar to frequencies in India. https://en.wikipedia.org/wiki/List_of_WLAN_channels#India , with the main difference being the higher frequencies are marked as "Yes" in North America a "Indoors" for India. Page 139 of the User Manual specifies which frequencies are used in the US vs. Europe. (This is a bit confusing since many products identify frequencies in more detail (Japan, Russia, etc. etc.)
As you already have them, I'd say, "Go for it."
- 2squaredJun 27, 2022Aspirant
Thanks a lot for your reply. I guess my only issue is with the power supply; though many posts seem to indicate that the adapter does support 100-240V, but its just mislabeled. Wonder if its worth a try using the included adapter.
If you use an adapter, there is zero chance of anything going wrong 'power-wise'.
