2squared
Jun 27, 2022Aspirant
Orbi RBK13 Voltage Support
I'm planning to buy Orbi RBK13 in USA and use it in India. Would it work without any issues? Also, the adapter reads 100-120v. But the voltage in India is 220v. I've read multiple posts saying that...
CrimpOn
Jun 27, 2022Guru - Experienced User
If you use an adapter, there is zero chance of anything going wrong 'power-wise'.
CrimpOn
sorry, I read that wrong. Using the US power supply with a voltage/plug converter is 100% safe.
Using only a plug converter might be exciting.
- 2squaredJun 27, 2022AspirantHeh heh...might be worth a try if I'm feeling especially adventurous đ .
Looking at the forums; some people have succeeded, so might be a shot in the dark, I guess.
