valendy
Jun 14, 2020Aspirant
orbi rbk20 router offline satelline online
Buongiorno ho recentemente acquistato un orbi rbk20 e non riesco ad installarlo correttamente. Scaricato app, collegato al mio modem wifi telecom, seguita procedura ma poi l'app mi dice che non r...
Jun 14, 2020Guru - Experienced User
In inglese per favore
valendy
Jun 15, 2020Aspirant
Good morning
I recently purchased an orbi rbk20 and I can not install it properly.
Downloaded app, connected to my modem wifi telecom, followed procedure but then the app tells me that it does not detect internet connection (in fact it signals to me router only local offline connection) while the network map signals me green internet - red router -green satellite.
I have the PC connected with ethernet cable to the orbi router and it is working perfectly, a kindle reader that reports no internet connection but works the same, a couple of connected devices that regularly work sky not connected and a coverage with the orbi network of the house not at all satisfactory (less than TPlLink I had previously).
Mah....
thank you for your help
Andrea
- FURRYe38Jun 15, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-appThere seems to be some problems regarding the Orbi app currently.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Good Luck.
