Kaiyuanben
Aug 18, 2019Aspirant
ORBI RBK20 with Bell 1G Fiber in Canada
Hi, I am using Orbi rbr20 with Bell Fiber 1000mb down and 750mb up in Canada. The modem provided by Bell is Home Hub 3000 (hh3000), it also has router funciton built-in. When I run speedtest (ht...
Aug 18, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2...
I would contact NG support about this as well if you can't get speeds near 900Mbps on the RBR.
Kaiyuanben
Hi,
FURRYe38 wrote:What Firmware is currently loaded?
The latest firmware (2.3.5.26) is loaded.
Modem Combo Units:
Couple of options,
There is no setting to config the modem to bridge mode.
I already disable the wifi function on the modem. Already did the DMZ on the modem for my Orbi rbr20.
The wifi functionality has been disable on the modem.
Try option #2...
- FURRYe38Aug 20, 2019Guru - Experienced User
What happens if you configure the RBR for AP mode and speed test with a wired PC connected to the RBR?
FYI:
- KaiyuanbenAug 20, 2019AspirantThanks Furrye38.
AP mode also showes me around 500mb download speed.- FURRYe38Aug 20, 2019Guru - Experienced User
I would make contact with NG support to see if the 20 series supports 1Gb WAN to LAN speeds then...
