springy
Jun 03, 2020Initiate
Orbi RBK20 with Sky Plus HD
Have just set up Orbi RBK20 via my PlusNet hub and Sky+ box is connected to Orbi via wireless however On Demand is now not available and recordings are failing. Has anyone had this issue and success...
- Jun 03, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
springy wrote:Have just set up Orbi RBK20 via my PlusNet hub and Sky+ box is connected to Orbi via wireless however On Demand is now not available and recordings are failing.
Has anyone had this issue and successfully resolved it?
Jun 03, 2020Guru - Experienced User
Do you have it setup like this?
plusnet hub------>orbi router------->sky+ box?
Is the plusnet hub in passthrough/modem only mode?
or the orbi in access point mode?
You could be in a double nat and the sky+ box not on the same subnet as the plusnet hub which could cause it to not record/view. https://kb.netgear.com/30186/What-is-Double-NAT
springy
Thanks all for the advice - it is connected plusnet hub--->orni router/satellite--->sky+ box
Having managed to get into the Orbi set up, I have switched it from router mode to AP mode and this seems to have resolved the issue
- FURRYe38Jun 03, 2020Guru - Experienced User
Good to hear. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
