Conny999
Feb 05, 2020Aspirant
Orbi rbk20
Today my internet connection went down frequently. Not the first time and a friend with same Orbi router experience the same problems at the same time. Anyone with a solution or explanation to this?
Feb 05, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Conny999
Feb 06, 2020Aspirant
Latest version.27, size of home doesn’t matter since the router is the problem. Switched back to my old router and instantly all problems were gone. This happens once a month (approximately) - as I said, a friend with the same equipment with a diffrerent provider has the same problems at the same time (once a month)
