Conny999
Feb 05, 2020Aspirant
Orbi rbk20
Today my internet connection went down frequently. Not the first time and a friend with same Orbi router experience the same problems at the same time. Anyone with a solution or explanation to this?
Feb 05, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Conny999
Feb 06, 2020Aspirant
Didn’t mention, last month I did a total reset, even the staellite worked for a week. Now it’s back. Exactly the same scenario at my friends house
