arigross
Jul 07, 2020Follower
orbi rbk20w
what is better for home? orbi RBK20W or Netgear Nighthawk AX4 AX3000 Wi-Fi 6 Router??
Jul 07, 2020Guru - Experienced User
Also consider your home size as well.
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-System
The Orbi AX surpasses the RBK20 on many levels
arigross wrote:what is better for home?
