thomer41
Feb 09, 2020Aspirant
Orbi RBK22 - Diminished Speed when Connected to LG OLED55B7P TV (both Wireless and Ethernet)
I just purchased an Orbi RBK22 and set it up right out of the box without any problems. I tested the speed and was getting what I expected, just over 100 mbs. I went to connect my LG OLED55B7P TV to ...
Feb 10, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
thomer41 wrote:I just purchased an Orbi RBK22 and set it up right out of the box without any problems. I tested the speed and was getting what I expected, just over 100 mbs. I went to connect my LG OLED55B7P TV to the wireless which connected fine, but the speed dropped drastically to 20-30 mbs. I tried hardwiring via Ethernet cable from the satellite directly to the TV and got the same results.
I have Spectrum internet (100 Mbs) with their cable modem: Ubee DDW36C.My Orbi is from Costco: RBK22 (NETGEAR Orbi Mini AC2200 Tri-Band Wi-Fi System, 2-pack)
