French_guy's avatar
French_guy
Follower
Apr 20, 2019
ORBI RBK22 - Router pulsating white
I did upgrade to the newest firmware V2.3.1.48 this morning on my Orbi system (router + 1 satellite)
Everything seems to work (internet works fine and the satellite is detected, and doesn't show any specific light) but the router is still pulstating white.....It's been more than  4 hours now since I did the upgrade. And the very last thing I did was to enable MU-MIMO (can't recall if it's pulsating after the firmware update or enabling the MU-MIMO)
What does white pulsating mean?
What should I do?
Thanks
Thanks
1 Reply
  • FURRYe38's avatar
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Try a factory reset on the system and setup from scratch.
    What should I do?
    Thanks
    Thanks
