Bill_Pgh
Feb 21, 2019Star
Orbi RBK22 - Verizon Fios Gigabit - NordVPN Issue
I need some help with a situation I've recently experienced. Sorry in advance for the long post. First some backstory.
I recently upgraded to Verizon Fios Gigabit service. This required that I...
- Feb 21, 2019
I would connect up all your devices to the Orbi system and not connect them to the FIOS system and see how it goes in AP mode.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Bill_Pgh
Feb 21, 2019Star
Distance is perhaps 100 feet but numerous walls. The Verizon tech who installed the Quantum router said there was no way to get to the basement with Ethernet as the original wiring was done before the walls were in place. No gaps in the walls due to foam insulation after the walls went up. The Verizon tech stated that the Wi-Fi Extender simply imports all of the Garage Quantum router's settings, so in effect, connecting to the Extender is the same as connecting directly to the router. If true, I assume connecting the Orbi to the LAN port on the Extender should work just fine. I will try it when I get home.
Here's the extender in case you are interested: https://www.verizon.com/home/accessories/fios-network-extender/
All of the ONTs in my plan are in the garage...
Not 100% sure on the exact model of the T-Link switch. I believe it's an inexpensive TL-SG1008D.
Really appreciate your help. Thanks.
Feb 21, 2019Guru - Experienced User
Let us know how it goes.
- Bill_PghFeb 21, 2019Star
Definitely will. So just switching the Ethernet from the Fios to the Orbi should be all that's necessary? No setting changes required on the Orbi? I'm assuming not, but wanted to make sure.
I'll post later with my findings after making the change.
Thanks again!
- FURRYe38Feb 21, 2019Guru - Experienced User
Yes. If you've already set up the Orbi for Ap mode, then connect the LAN cable to the WAN port of the Orib base.
Will do. Thanks. Will report back with the findings.
:smileywink:
Home now and plugged switched the ethernet from the Fios Extender to the Orbi. All seems to be working fine. I still have a question.
If, prior to switching the cable, the Orbi is in AP mode and provding the Wi-Fi, and the Fios router is providing the ethernet connections, what exactly have I accomplished by plugging the ethernet into the Orbi?
It would make sense to do this if was putting the Orbi in "Router" mode because then the wired and wireless would be on the same network. But in AP mode, it's all the same network anyway, so I don't understand what doing what I just did accomplished. It hasn't hurt anything, but what's the benefit?
Thanks.
Since your FIOS already had a router, using the Orbi in Router mode would cause problems. This would be a double NAT condition which isn't recommended.
http://computer.howstuffworks.com/nat.htm
http://www.practicallynetworked.com/networking/fixing_double_nat.htm - Bill_PghFeb 21, 2019Star
Got it. Thanks. Not sure that answers my last question, but that's ok. All is working fine now.
You helped a great deal! Much appreciated. Thanks so much for the help!
No benefit in double nat. Single NAT condition is best and preferred. Less hassle and troubleshooting is the benefit here. :smileywink:
Enjoy.
Working great! Thanks!
:smileyvery-happy:
