alisrael
Jul 06, 2019Aspirant
ORBI RBK22 5GHz has no devices connected
Hi , I recently replace my WNDR3800 router with ORBI RBR20, and RBS20. Connected per the setup documentation. My satellite is connected with a good signal, and the router is very close my de...
alisrael
Jul 08, 2019Aspirant
I have the latest firmware 2.3.5.26. I am using the ISP provider's modem. The home is about 3000 Sq. Ft. The distance between the router and the satellite is less than 20 feet, and the connection shows good. There are a few, and I cannot disable 2.4, as all my smart home devices require 2.4 GHz. I ended returning the unit, and buying a Netgear Nighthawk X6s AC3600, and everything is working fine. However, I have the smart connect disabled, and I have three separate SSIDs, which is still ok, as I have excellent coverage of the 5Ghz throughout the house now.
Thanks for your help.
Jul 08, 2019Guru - Experienced User
20 feet is too close between the RBR and RBS. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
You can temporarily disable the 5Ghz SSID broadcast on the Orbi while you get the 2.4Ghz devices set up.
These were probably some conditions that could have been corrected to get your devices connected. Oh well.
Good Luck.
