Mozilla168
Jan 26, 2020Aspirant
Orbi RBK22 Keeps dropping internet connection
I set up an rbk22 (Rbr20 + satellite) weeks ago and it worked fine. The rbr20 is wired to my modem and the satellite wirelessly. Firmware is the latest on both (2.3.5.36) In the last Week, it ke...
Jan 27, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
In the last Week, it keeps dropping connection. Either the light is off but there is no internet or I notice it's violet.
I have to keep rebooting and it's driving everyone in the house crazy.
It started when my daughter got an iPhone 11 but that may just be a coincidence. That was the only thing that changed from the time it was working fine and started acting up.
I have circle installed and it also keeps discontinuing the premium subscription. I don't know if that's related though.
Mu-mimo and beamforming are Both enabled.
Fast roaming is disabled.
Hope this gets fixed soon. Driving me nuts
Thanks
- Mozilla168Jan 27, 2020AspirantOK i tried a trial and error process.
I first turned off the satellite and the main rbr20 unit has been working fine for 24hours now. So it must be the connection to the satellite that is causing the problem- FURRYe38Jan 27, 2020Guru - Experienced User
Please give feedback to the question presented.
- Mozilla168Jan 28, 2020AspirantReply sent
- Mozilla168Jan 28, 2020AspirantWhat is the Mfr and model# of the ISP modem the NG router is connected too?
-Prolink H5204NK
- 1,980 SF (3 stories. Signals mostly needed in 2nd floor so both router and satellite are in the 2nd floor
- 10 ft
2.4= auto
5 = 48
I can see signals from 2 neighbors when in the ground floor, but none on the 2nd floor where the or is area
Will try these- FURRYe38Jan 28, 2020Guru - Experienced User
-Prolink H5204NK
This is a modem/ router built in already:
http://www.rivijayaweera.com/public_html/?p=1108
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- 10 ft <This is too close to the RBR. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
2.4= auto
5 = 48
Will try these- Mozilla168Jan 28, 2020AspirantThank you.
I can't access the modem admin panel because the isp disallow it.
I may have to buy a modem which I can freely configure.
I'll try the other suggested solutions in the meantime.
Thanks!
