Mozilla168
Jan 26, 2020Aspirant
Orbi RBK22 Keeps dropping internet connection
I set up an rbk22 (Rbr20 + satellite) weeks ago and it worked fine. The rbr20 is wired to my modem and the satellite wirelessly. Firmware is the latest on both (2.3.5.36) In the last Week, it ke...
Mozilla168
Jan 28, 2020Aspirant
-Prolink H5204NK
- 1,980 SF (3 stories. Signals mostly needed in 2nd floor so both router and satellite are in the 2nd floor
- 10 ft
2.4= auto
5 = 48
I can see signals from 2 neighbors when in the ground floor, but none on the 2nd floor where the or is area
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Will try these
-Prolink H5204NK
- 10 ft
2.4= auto
5 = 48
Will try these
Jan 28, 2020Guru - Experienced User
-Prolink H5204NK
This is a modem/ router built in already:
http://www.rivijayaweera.com/public_html/?p=1108
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- 10 ft <This is too close to the RBR. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
2.4= auto
5 = 48
Will try these
- Mozilla168Jan 28, 2020AspirantThank you.
I can't access the modem admin panel because the isp disallow it.
I may have to buy a modem which I can freely configure.
I'll try the other suggested solutions in the meantime.
Thanks!- FURRYe38Jan 28, 2020Guru - Experienced User
:smileywink:
- Mozilla168Feb 01, 2020AspirantThe Orbi internet was still unstable despite unchecking the suggested settings and moving the satellite farther away.
I bought a tp-link modem/router to replace my ISP's modem. I set it to bridge mode and things seem to be ok now. I've not yet set up the satellite and will observe the performance today first.
