fteng12
Jun 29, 2018Aspirant
Orbi RBK22 wireless connection problem to Netgear Synology Diskstation
I have a Synology Diskstation (DS212) that I use to backup files and as a central drive for my house. I used to be able to access the Diskstation wirelessly with my old router with no problems. Now...
Jun 29, 2018Guru - Experienced User
What is the Mfr and model# of this swtich? Managed switch or non managed switch? There are some users seeing problems with Managed switches if you are using one with Orbi systems.
Yes long term, using a switch will work fine. Just need to find out if this is a router, NAS or swich problem. Putting the NAS directly connected to the router with the laptop will help narrow this down more.
