TRBN
Sep 08, 2019Tutor
Orbi RBK22
Hi, Disappointed as my RBK22 is not covering even 2000 Sq Ft area where my old Net Gear R 7000 is doing a good job for the same area and with the same position Can some one hlep me, if i have miss...
TRBN
Sep 08, 2019Tutor
Hi
Sorry for not making my point clear
Yes it is RBR20+RBS20 which is sold as RBK22.
You have understood my issue.
Yes I have place RBR 20 exactly in place of R7000 which i replaced by this Orbi system. I have kept RBS-20 at about 20 ft from RBR20.
My point is when i use my ipad at a distance between 25-30 ft from RBR20 without switiching RBS20, the signal shows poor and for sure no video gets played. Whereas when i was using R-7000, the signal was good enough for online video to play without any problem
Thank you for your understading and please let me know is there any fine tuning i need to do in terms of configuring RBR20
Regrds
CrimpOn
Sep 08, 2019Guru - Experienced User
I have not seen a picture of the "insides" of the RBR20. (There are some really cool "explosions" of the RBR50 on the Netgear site.)
However, my guess is that the RBR20 antennas may not have the same "gain" as the R7000 antennas. Antenna orientation is a mystic art, and it could be that rotating the RBR20 would move the direction of the strongest signal.
Please explain "without switching RBS20". I am assuming that you mean not powering on the RBS20.
Just as a note, the proper distance between the router and the satellite is complicated. When they are "close", the backhaul WiFi signal between them is stronger, and thus the backhaul better. However, when they are very close, since they are both broadcasting on the same WiFi channel, they interfere more. 20 ft. apart may turn out to be too close (when you turn it on).
At this point, I am hoping that one of our "radio experts" will jump in and explain how a single RBR20 should compare to a single R7000.
