Otuis
Apr 22, 2020Guide
Orbi RBK22
I M CONNECTED TO WIFI ON MY IPHONES BUT WHEN I TRY TO CONNECT A PC OR LAPTOP IT SAYS CAN'T CONNECT TO THIS NETWORK??
Otuis
Apr 22, 2020Guide
It says invalid password on both pc or laptop firmware is up to date i try to update i have a Comcast Modem and the Orbi is connected to it as I said before I am connected to internet on my iphone thru Orbi
Apr 22, 2020Guru - Experienced User
Otuis wrote:It says invalid password on both pc or laptop firmware is up to date i try to update i have a Comcast Modem and the Orbi is connected to it as I said before I am connected to internet on my iphone thru Orbi
1. Punctuation. Please
2. What model comcast modem? These details are key.
3. What firmware is it? The latest isn't a number and many times it isn't "the latest" and "the latest" changes.
4. Does a hardwired connection work?
5. Again, did something change? is this a new install? Did it work prior? You didn't go into any more details. I want to help but you need to help us so we can help you.
- OtuisApr 22, 2020Guide
the Comcast modem it's a Xfinity XB6-A, it's a new install,
i did the set up this morning now it says can't connect to this network when i try to connect a laptop
- FURRYe38Apr 22, 2020Guru - Experienced User
Modem Router Combo units from ISPs. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Otuis wrote:the Comcast modem it's a Xfinity XB6-A, it's a new install,
Thank you, that makes sense! So i Am probably double NAT now if i disable my Xfinity modem will I be able to watch TV? Probably not right?
