Otuis
Apr 22, 2020Guide
Orbi RBK22
I M CONNECTED TO WIFI ON MY IPHONES BUT WHEN I TRY TO CONNECT A PC OR LAPTOP IT SAYS CAN'T CONNECT TO THIS NETWORK??
Otuis
Apr 22, 2020Guide
Thank you, that makes sense! So i Am probably double NAT now if i disable my Xfinity modem will I be able to watch TV? Probably not right?
Apr 22, 2020Guru - Experienced User
You'll need to contact your ISP to see what option is best for your ISP modem with out TV interuptions.
The easiest method would be option #3...
You can try Option #2 as well.
