Graig
Aug 30, 2022Aspirant
Orbi RBK23 - Can I force Daisy Chaining?
I own a NETGEAR Orbi Whole Home Mesh WiFi System - AC2200 (RBK23) and I'm having some issues. I have two satellites (RBS20); one about 40 feet away from the router (RBR20) and one floor down, and the...
Graig
Aug 31, 2022Aspirant
Hi Kevin.
Thanks for the reply, but this isn't helpful. My two satellites are pretty much in-line with one another, with the second satellite more distant than the first and getting a poor connection to the router, yet it never tries to daisy chain off the first satellite.
Why doesn't it daisy chain off the first satellite? Is there a way to force it to connect to the first satellite?
For an expensive mesh WiFi system, getting things to work properly shouldn't be this difficult.
Thanks.
CrimpOn
Aug 31, 2022Guru - Experienced User
It is fortunate that satellites are portable. What happens if the far satellite is temporarily relocated to another location that is closer to the near satellite, but still farther away from the router?
My #1 troubleshooting technique has always been, "turn it off and back on again." What happens if the entire system is powered off and then restarted one-at-a-time beginning with the router, then near satellite, then far satellite? (at least a couple of minutes between each unit.)
