gcorbett99
Dec 29, 2020Follower
Orbi RBK23 AC2200
I would looking for information on higher gain antennas/cables/connectors for this router for better connection to Verizon 4GLTE.
Thanks! Gary
1 Reply
Orbi systems have internal antennas only for wifi which broadcasts it's own wifi signal. Also the Orbi RBK23 supports only connection to a DSL, FiberONT or cable modem interfact using RJ45 cable LAN connection. If your ISP LTE modem has a RJ45 port, then this modem could be used ad the ISP connection to the ISP services. CAT6 LAN cable is recommended between the ISP modem and RBR.
Contact the ISP about configuration information regarding there modem and use with external connected routers.
