Me3
Apr 17, 2020Aspirant
Orbi RBK23 Allocating to a specific piece of equipment
Hi New here Just my my Orbi unit with 2 satellites. I’ve set them up (eventually) and all seems fine. However my Xbox is linking to the satellite upstairs not the one I have positioned next to it!!...
Retired_Member
Apr 17, 2020what difference does it make?
if you have a sat sitting next to the xbox, just connecy it with a ethernet cable
Me3
The Xbox speed seems faster without the Ethernet connection for some reason
- Retired_MemberApr 17, 2020
Me3 wrote:
The Xbox speed seems faster without the Ethernet connection for some reasonwell there's your answer.
I have mine sitting right next to one of the sats connected with a ethernet cable and it seems fine. I don't worry about where the devices connect to, as long as they 'work' as they should.
