Bradjeee
Aug 28, 2019Initiate
Orbi rbk23 device list incorect
Hi guys and girls, I have two problems with my orbi RBR20 system with two satalites (running on V2.3.5.26): 1. My router only sees one satalite. I already reset the whole system but it still ...
Aug 28, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Are the satellites all wireless connected to the RBR?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
