DougMitchell
Dec 19, 2019Follower
Orbi RBK23 Ethernet connection to Fetch TV box
I have installed the Orbi RBK23 wifi system and that is working well, but I cannot conect my Optus Fetch TV box to the ethernet connection. Also it does not connect to the Orbi wifi. The box says it ...
Dec 20, 2019Guru - Experienced User
Do other devices connected to the LAN ports on the Orbi?
Contact the Mfr of this Fetch TV box for there help and information. Does this TV box require specific services to work correctly?
DougMitchell wrote:I have installed the Orbi RBK23 wifi system and that is working well, but I cannot conect my Optus Fetch TV box to the ethernet connection. Also it does not connect to the Orbi wifi. The box says it detects an excellent wifi connection speed but does not connect.
