Nnyan
Aug 11, 2020Tutor
ORBI RBK23 in Router Mode can not set custom DNS
Hello all, just deployed 3 node RBK23 in one of my locations and everything is fine except that even though I am in router mode the only way that I can put in my own custom DNS (off of the ISP provid...
- Aug 11, 2020
When the Orbi was installed, did you activate Disney Circle? I have seen a number of posts about specifying DNS servers, and it appears that Disney Circle blocks the ability to designate DNS servers on the setup screen. The "fix" appears to be deactivating Disney Circle, rebooting, setting up the desired DNS servers, and then (if you REALLY want it) reactivating Disney Circle.
CrimpOn
Aug 11, 2020Guru - Experienced User
Nnyan
Aug 13, 2020Tutor
It seems like I did activate this to check it out and turned it off but even though I thought I had rebooted it looks like I had not since a reboot and relogin and it's not greyed out anymore!
Thank you
- CrimpOnAug 13, 2020Guru - Experienced User
If you mark the problem "Solved", that will let people know you solved it.
