Nnyan's avatar
Nnyan
Tutor
Aug 11, 2020
ORBI RBK23 in Router Mode can not set custom DNS
Hello all, just deployed 3 node RBK23 in one of my locations and everything is fine except that even though I am in router mode the only way that I can put in my own custom DNS (off of the ISP provid...
  • CrimpOn's avatar
    Aug 11, 2020
    When the Orbi was installed, did you activate Disney Circle?  I have seen a number of posts about specifying DNS servers, and it appears that Disney Circle blocks the ability to designate DNS servers on the setup screen.  The "fix" appears to be deactivating Disney Circle, rebooting, setting up the desired DNS servers, and then (if you REALLY want it) reactivating Disney Circle.
