Pinkleton
Jan 20, 2019Tutor
Orbi RBK23 LAN Connections Fail Cross-Satelites
Firmware Version: V2.2.1.210 Bought the three pack (RBR20 with two RBS20) on Amazon and I have this certain odd issue. It seems like LAN IP addresses are not being passed through within the three sa...
- Jan 20, 2019
Pinkleton wrote:
All satelites were using WiFi backhaul when the issue occurs. I did not attempt disabling daisy chain to resolve the issue, but if that truly was the cause then I would most definitely consider this a firmware related issue that needs resolving from Netgear.
Yes, I agree. Daisy Chain has some bugs today, also handling of wired devices in Orbi has some glitches that need to be solved.
I really hope that Netgear will fix those issues in the coming releases.
ekhalil
Jan 20, 2019Master
I assume here that you’re using Orbi in Router Mode?
My guess is that the wired devices are getting their IP addresses fron your ISP router and not from Orbi.
Please make sure that your ISP router is bridged if you want to keep Orbi in Router Mode.
Pinkleton
Jan 20, 2019Tutor
The Orbi is the only DHCP server in the house. Upstream to the Orbi would only be my modem.
- ekhalilJan 20, 2019Master
When you got the connectiivity issue did you have a mix of wired and wireless backhaul satellites? There are reported issues affecting wired devices when you have a mix of wired and wireless backhaul. Please see here: https://community.netgear.com/t5/Orbi/NETGEAR-Orbi-AC3000-satellite-LAN-ports-stopped-working/m-p/1692454/highlight/true#M50302. A workaround to solve this issue is to disable Daisy Chain. Do you have Daisy Chain enabled? Please test to disable it and see if that helps.
- PinkletonJan 20, 2019Tutor
