Pinkleton's avatar
Jan 20, 2019
Orbi RBK23 LAN Connections Fail Cross-Satelites
Firmware Version: V2.2.1.210 Bought the three pack (RBR20 with two RBS20) on Amazon and I have this certain odd issue. It seems like LAN IP addresses are not being passed through within the three sa...
  • ekhalil's avatar
    ekhalil
    Jan 20, 2019
    Pinkleton wrote:
    All satelites were using WiFi backhaul when the issue occurs. I did not attempt disabling daisy chain to resolve the issue, but if that truly was the cause then I would most definitely consider this a firmware related issue that needs resolving from Netgear.
    Yes, I agree. Daisy Chain has some bugs today, also handling of wired devices in Orbi has some glitches that need to be solved.
    I really hope that Netgear will fix those issues in the coming releases.
