Pinkleton
Jan 20, 2019Tutor
Orbi RBK23 LAN Connections Fail Cross-Satelites
Firmware Version: V2.2.1.210 Bought the three pack (RBR20 with two RBS20) on Amazon and I have this certain odd issue. It seems like LAN IP addresses are not being passed through within the three sa...
- Jan 20, 2019
Pinkleton wrote:
All satelites were using WiFi backhaul when the issue occurs. I did not attempt disabling daisy chain to resolve the issue, but if that truly was the cause then I would most definitely consider this a firmware related issue that needs resolving from Netgear.
Yes, I agree. Daisy Chain has some bugs today, also handling of wired devices in Orbi has some glitches that need to be solved.
I really hope that Netgear will fix those issues in the coming releases.
ekhalil
Jan 20, 2019Master
When you got the connectiivity issue did you have a mix of wired and wireless backhaul satellites? There are reported issues affecting wired devices when you have a mix of wired and wireless backhaul. Please see here: https://community.netgear.com/t5/Orbi/NETGEAR-Orbi-AC3000-satellite-LAN-ports-stopped-working/m-p/1692454/highlight/true#M50302. A workaround to solve this issue is to disable Daisy Chain. Do you have Daisy Chain enabled? Please test to disable it and see if that helps.
Pinkleton
Jan 20, 2019Tutor
- ekhalilJan 20, 2019Master
- PinkletonJan 27, 2019Tutor
Putting the above reply as the accepted answer, as I would argue this is a firmware issue that needs resolving from Netgear.
