Pinkleton
Jan 20, 2019Tutor
Orbi RBK23 LAN Connections Fail Cross-Satelites
Firmware Version: V2.2.1.210 Bought the three pack (RBR20 with two RBS20) on Amazon and I have this certain odd issue. It seems like LAN IP addresses are not being passed through within the three sa...
- Jan 20, 2019
Pinkleton wrote:
All satelites were using WiFi backhaul when the issue occurs. I did not attempt disabling daisy chain to resolve the issue, but if that truly was the cause then I would most definitely consider this a firmware related issue that needs resolving from Netgear.
Yes, I agree. Daisy Chain has some bugs today, also handling of wired devices in Orbi has some glitches that need to be solved.
I really hope that Netgear will fix those issues in the coming releases.
Pinkleton
Jan 20, 2019Tutor
ekhalil
Jan 20, 2019Master
- PinkletonJan 27, 2019Tutor
Putting the above reply as the accepted answer, as I would argue this is a firmware issue that needs resolving from Netgear.
