charleyp1
Dec 06, 2022Star
Orbi RBK23 Router solid magenta
I've been having intermittent internet connectivity through my wifi signal (both 2.4 and 5ghz) and the Router (not the satellites) ring is solid magenta. I have several devices that are connected via...
- Dec 07, 2022
Even in AP mode, you still connect the main RBR using its wan port.
That could be why its magenta
Dec 07, 2022Guru - Experienced User
charleyp1
Dec 07, 2022Star
Well, snap. You’re right. I moved the connection from a LAN port to the WAN port and bounced the Orbi again and it came back. No magenta light for almost 2 hours. Thanks! Crazy that it was a simple thing.
