Emperor1
Jun 14, 2018Guide
Orbi RBK23 slow internet connection (with network cat 7 to fiber FTTH 1 GIGA)
Hi, just received Orbi RBK23 kit.
I've setup main Orbi device, and configured as access point.
I've connect it direcly using a CAT 7 network cable to my router (fastweb) 1 GIGA fiber FTTH.
I re...
Emperor1
Jun 14, 2018Guide
Thanks,
just to better understand.
1. 2. 3. there's a better option between the 3 or they're similiar in term of final performances ?
i've for sure disabled the wi-fi module on my modem and active Orbi as router ... but really don't know how to configure the DMS as indicated for point 2.
I've connected the Orbi router to my modem using a network cable ... so i should change Orbi as AP mode ?
In the meantime i've received also 3 RBK53 and it's way better ...
Very last: "you do not enable speedtest app, traffic meter or access controls on the Orbi router as these have been found to slow internet speeds at 1Gb services".
Are you referring at the option 'Internet speed' available into the Netgear Orbi (for iPhone) App ? I've not to use it ?
Jun 14, 2018Guru - Experienced User
Nothing in between 2 and 3. The ISP modem can be a factor in performances if there is routing there in volved. Reason why using DMZ if the modem can't be bridge should help for this if you use the Orbi in router mode.
If your not going to use the Orbi as yoru router, then yes, AP mode would be perferred.
The speed test app with in the routers web page.
