Cnacopy
Aug 02, 2020Aspirant
Orbi RBK23 Started Blocking My Coporate Web site
I've had the Orbi RBK23-100NAS since January 2nd. The other day as I was working on my company's web site (https), Orbi decided to just prevent me from viewing the site anymore. If I connect directly...
Aug 02, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Cnacopy wrote:I've had the Orbi RBK23-100NAS since January 2nd. The other day as I was working on my company's web site (https), Orbi decided to just prevent me from viewing the site anymore. If I connect directly to my cable moden (no wi-fi on the cable modem), I have no issue, so it's definitely Orbi causing the problem. I updated the firmware, rebooted, unplugged all connections and restarted, added https domains to always allow access under the Block Services tab of orbilogin.com. Nothing works and I see this is a consistent problem with Orbi and Netgear is aware but hasn't fixed it. I did not activitate Armor or Circle on it so there's no domain monitoring or blocking software. Appreciate any suggestions as I'm at the point I'm ready to throw out Orbi!
Cnacopy
Thanks. Appreciate the tips. I'm on V2.5.1.16. I updated to the latest firmware after the problem started. Just tried everything you mentioned, including resetting, and still can't access the website. I get the error message - The connection has timed out. The server is taking too long to respond. But there's nothing wrong with the website.
- FURRYe38Aug 02, 2020Guru - Experienced User
Someting to contact the web master of the web site to see whats going on.
Cnacopy wrote:Thanks. Appreciate the tips. I'm on V2.5.1.16. I updated to the latest firmware after the problem started. Just tried everything you mentioned, including resetting, and still can't access the website. I get the error message - The connection has timed out. The server is taking too long to respond. But there's nothing wrong with the website.
