nateypants
Jun 14, 2020Aspirant
ORBI RBK23 VLAN tagging / setup for both internet and iptv - Bell Fibe
Hello - I am considering replacement of the TP-Link Deco X20 device with the Netgear RBK23 Tri-band mesh wifi. We are on Bell Fibe IPTV & internet services in Ontario, Canada. What I would like to do...
Jun 18, 2020Guru - Experienced User
Any VLAN tagging would be done from the RBRs web page.
Review the user manual for setup information.
Do a search here in the foruns for VLAN posts.
nateypants
Jun 18, 2020Aspirant
FURRYe38 wrote:Any VLAN tagging would be done from the RBRs web page.
What is not clear to me is whether VLAN tagging is for a specific LAN port on the Orbi device or a specific SSID or broadly for wireless connections? Any additional information on this point?
- FURRYe38Jun 18, 2020Guru - Experienced User
I believe the VLAN tagging is for only WAN side configurations.
- nateypantsJun 18, 2020Aspirant
FURRYe38 wrote:I believe the VLAN tagging is for only WAN side configurations.
Sorry, I'm not clear on the response. To be more direct: once a VLAN is assigned, will a specific Ethernet port on the Orbi device now be tagged with the VLAN, or is the current wireless network now tagged with the VLAN? Another way: once VLAN tagging is enabled, do I need to plug my IPTV recieved via ethernet cable to the ORBI, or can it be connected wirelessly?
I would try wired first to see if the configuration works. Then try wireless.
Might review this:
https://community.netgear.com/t5/Orbi/Orbi-AC3000-RBR50-and-IPTV-via-Telenor/m-p/1694668
There maybe other VLAN configuration posts as well.
