nateypants
Jun 14, 2020Aspirant
ORBI RBK23 VLAN tagging / setup for both internet and iptv - Bell Fibe
Hello - I am considering replacement of the TP-Link Deco X20 device with the Netgear RBK23 Tri-band mesh wifi. We are on Bell Fibe IPTV & internet services in Ontario, Canada. What I would like to do...
nateypants
Jun 18, 2020Aspirant
FURRYe38 wrote:I would try wired first to see if the configuration works. Then try wireless.
Might review this:
https://community.netgear.com/t5/Orbi/Orbi-AC3000-RBR50-and-IPTV-via-Telenor/m-p/1694668
There maybe other VLAN configuration posts as well.
I am unable to find a post that clearly statest wireless VLAN tagging is available with latest Orbi RBK50 (or other) firmware. That is the reason for my post :) The above only *asks* about a wired configuration. Additional hardware will be required (i.e. media converter) and so, before I go there, I would like to know what is *currently* possible with VLAN tagging over a wireless network using the Orbi devices.
Jun 18, 2020Guru - Experienced User
- nateypantsJun 18, 2020Aspirant
Than
FURRYe38 wrote:https://community.netgear.com/t5/Orbi/But-Orbi-DOES-have-Vlan-tagging/m-p/1808711
Thank you. Unless something has changed with the firware since 2019, then this statement seems to sum it up from the link you posted: "As for managed switch I have a catalyst 3750 running happily with my Orbi in AP mode however you can’t assigned vlans to managed wireless clients like you could with a higher end AP such as something made by Aruba or Cisco."
Thanks for your help! Hope that the Netgear team will provide for VLAN tagging of multiple SSID's/wireless clients in the future!
- FURRYe38Jun 18, 2020Guru - Experienced User
Good Luck.
