nateypants
Jun 14, 2020Aspirant
ORBI RBK23 VLAN tagging / setup for both internet and iptv - Bell Fibe
Hello - I am considering replacement of the TP-Link Deco X20 device with the Netgear RBK23 Tri-band mesh wifi. We are on Bell Fibe IPTV & internet services in Ontario, Canada. What I would like to do...
nateypants
Jun 18, 2020Aspirant
FURRYe38 wrote:I would try wired first to see if the configuration works. Then try wireless.
Might review this:
https://community.netgear.com/t5/Orbi/Orbi-AC3000-RBR50-and-IPTV-via-Telenor/m-p/1694668
There maybe other VLAN configuration posts as well.
I am unable to find a post that clearly statest wireless VLAN tagging is available with latest Orbi RBK50 (or other) firmware. That is the reason for my post :) The above only *asks* about a wired configuration. Additional hardware will be required (i.e. media converter) and so, before I go there, I would like to know what is *currently* possible with VLAN tagging over a wireless network using the Orbi devices.
schumaku
Jun 18, 2020Guru - Experienced User
The IPTV VLAN should be bridged to a router (or more than one) port - there you can connect (by cables) the IPTV boxe(s) to. The IP addresses are coming from the ISP IPTV network, along with the video multicast streams.
The Internet VLAN will be bridged to a group where NAT will be handled. Here the Orbi behind of the NAT routing, DHCP will issue private LAN subnet adresses.
Having both over the Orbi backhaul is in my understanding not possibe, as tere is no VLAN support, while the Internet and the IPTV VLANs on the ISP side present two individual networks.
