Shery999
Jun 29, 2019Aspirant
Orbi RBK23 Wired Backhaul Through A Switch?
Hello internet, I just bought a RBK23 off amazon earlier which is due for delievery tommrow. I wanted to know if I can connect them for a wired backhaul through a network switch even though I kn...
Jun 29, 2019Guru - Experienced User
Yes you can:
Recommended switches to use are non mananged switches and switches with out any green tech ethernet features. If you use a managed switch, be sure to disable ALL IGMP protocls on it.
Shery999
thanks for that link pal. One more thing, do you think it would be better to connect router to a switch and then from switch connect the 2 satellites like its shown in the link you provided? or would it be better if I connect the router to satellite 1 and then from satellite 1 to switch and then run a cable from switch to satellite 2?
- FURRYe38Jun 29, 2019Guru - Experienced User
I presume either way would work however for more stability and less troubleshooting issues, I would connect both satellites more directly to a switch than daisy chain them of each other.
