Imulji
Sep 27, 2019Guide
ORBI (RBK23) with a second RBR
HI there,
I have the RBK 23 system (1 router and 2 satelittes) and the system works great but I have one dead spot for my wifi. Being that I am in Canada I cannot find or its cost prohibitive to find satellites, I bought a RBR40 from eBay for cheap.
I am aware that I can use the RBR in AP mode and wired which works great for my setup, but my question is, does adding another RBR in AP mode work with the mesh system or will it cause potentially Crossed channels as a result of adding another RBR?
If so any suggestions to minimize the issue?
Thanks!
RBRs can only work in main router mode or AP mode. Not as satellites.
Yes you can use the RBR in AP mode, however you need to keep the 2.4Ghz and 5Ghz channels between the two RBRs far appart. So RBR1 set 2.4Ghz to channel 1 and the RBR2 set to channel 11.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
