Nige147
Nov 07, 2019Aspirant
Orbi RBK23
Hi I’ve just bought a orbi RBK23 system I was just wondering when I set it up if I connect to my existing router from my Internet provider or do I unplug it and just connect the orbi
Retired_Member
Nov 07, 2019
The RBK23 is a router, therefore you don't 'need' another router. You can run 2 routers, but it requires special config and IMHO is not recommended.
You will need a modem
- Nige147Nov 07, 2019AspirantThanks
Looking forward to setting it up this weekend
I just hope it is as good as they say it is and improves my WiFi range
