edoardoscarpa
Nov 13, 2019Guide
ORBI RBK23
Ciao a tutti.
Ho acquistato da qualche mese il sistema orbi RBK23 (router + 2 satelliti) e funziona tutto perfettamente garantendomi la maggiore velocità in tutta la casa.
Tuttavia ho notato che, in particolare modo verso le 24, i satelliti diventano color rosso e il Wi-Fi si blocca su tutti i dispositivi. Ho provato ad usare un altro canale (di default è su “automatico”) ma la situazione non è cambiata anzi è forse peggiorata. Il firmware è aggiornato all’ultima versione.
Qualcuno saprebbe spiegarmi il motivo?
In inglese per favore
- Hello to all.
I have purchased the Orbi RBK23 system (router + 2 satellites) a few months ago and everything works perfectly, guaranteeing the fastest speed in the whole house.
However I have noticed that, in particular towards the 24, the satellites become red and the Wi-Fi freezes on all the devices. I tried to use another channel (by default it is on "automatic") but the situation has not changed or rather it has worsened. The firmware is updated to the latest version.
Can anyone explain the reason to me?- FURRYe38Guru - Experienced User
I
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
