Morikid
Feb 23, 2020Aspirant
Orbi RBK23
Just a general question, whether the RBK23 suitable for a 500mbps incoming service, or will the RBK50 would be better, its a medium size house with a garden room. Thanks
Feb 24, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem you currently have?
Thanks
- MorikidFeb 24, 2020AspirantVirgin Media Smart hub3, at the router using my iphone 10, I get about 400-530mbps on wifi. Brilliant, but everywhere else in the house it ranges from 30-80mbps. Having read about the capability of the Orbi 23, thought that might improve my home wifi generally. As my service is 500mbps, the RBK23 is rated ideal for 200mbps.. thats means although i have 500 at my router, if using RBK23 I would be limited to a 200mbps !! Not sure
