Morikid
Feb 23, 2020Aspirant
Orbi RBK23
Just a general question, whether the RBK23 suitable for a 500mbps incoming service, or will the RBK50 would be better, its a medium size house with a garden room. Thanks
Morikid
Feb 24, 2020Aspirant
Thank you for the insight of the product & capability. I am UK VIRGIN MEDIA services on a 500mbps service. Their hub is a smart hub 3, but in my opinion & research that hub has poor wifi ping as soon as you move out of the Room the router is in. Thought that the RBK50 would be ideal but costly !! That why I was looking at the cheaper RBK23.. if that make sense 👍🏼😊
Feb 24, 2020Guru - Experienced User
Ok having two routers on the same line may cause some problems. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would go for option #3 first.
- MorikidFeb 24, 2020AspirantBest option in my opinion would be use Virgin hub in Modem mode only as I am not brilliant about configuring routers & use the Orbi Router & connect the orbi satellites to it . However I will read the links that you have supplied to gain knowledge. Thank you for all the help. Now need to decide Which orbi to buy ....
- FURRYe38Feb 24, 2020Guru - Experienced User
Yes modem in modem mode only would be best. Contact your ISP for help regarding this.
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-SystemsGood luck.
- MorikidFeb 24, 2020AspirantThank you for all your help
