Morikid
Feb 23, 2020Aspirant
Orbi RBK23
Just a general question, whether the RBK23 suitable for a 500mbps incoming service, or will the RBK50 would be better, its a medium size house with a garden room. Thanks
Feb 24, 2020Guru - Experienced User
Ok having two routers on the same line may cause some problems. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would go for option #3 first.
Morikid
Feb 24, 2020Aspirant
Best option in my opinion would be use Virgin hub in Modem mode only as I am not brilliant about configuring routers & use the Orbi Router & connect the orbi satellites to it . However I will read the links that you have supplied to gain knowledge. Thank you for all the help. Now need to decide Which orbi to buy ....
- FURRYe38Feb 24, 2020Guru - Experienced User
Yes modem in modem mode only would be best. Contact your ISP for help regarding this.
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-SystemsGood luck.
